Windows hidden dir display in WinSPC
Re: Windows hidden dir display in WinSPC
WinSCP would automatically hide only files/folders that it knows to be "hidden".
Those are either files/folders starting with a dot. Or files/folders that the server explicitly marks s hidden. What only SFTP version 5 and WebDAV allows. Your server clearly does not do this.
Instead, you can setup a filter like $RECYCLE.BIN/;System Volume Information/.
https://winscp.net/eng/docs/ui_filter
But the filter is not persistent.
Rob73
The Netherlands
I am running Windows IIS as sever
This bring me to have a look IIS server
Yes It can be set, see attachment
Thanks for your communication, greet
Anonymous wrote:
Martin the filter option work fine
Now I want to make it default
As I wrote before, "filter is not persistent".
