GET in scripting gives error - Script: Failed - (WinSCP v5.11.2)
I found a BUG, this is the script (WinSCP v5.11.2):
WinSCP.com /console /script="C:\Cindy\pockets_recebe_winscp.ftp"
open ftp://xxxxx:*****@111.222.333.444.555
lcd C:\Cindy\Temp
cd envios
get 00equipinterval.txt
get 00modelequip.txt
get 054DlvUNLJM.*
get 054Prd*
get 054LocalVen.*
get 054SRA*
rm 054DlvUNLJM.*
rm 054Prd*
rm 054LocalVen.*
rm 054SRA*
rm 00equipinterval.txt
rm 00modelequip.txt
lcd %ScorpioPath%\Temp
get del*
rm del*
cd ..
If the file 00equipinterval.txt or 00modelequip.txt does not exist it gives error, and stops the rest of the script!
The complete error is in the LOG file attached.
> 2017-11-15 09:37:52.206 Script: get 00equipinterval.txt
> 2017-11-15 09:37:52.206 Script: Parameter: 00equipinterval.txt
. 2017-11-15 09:37:52.206 Listing file "00equipinterval.txt".
. 2017-11-15 09:37:52.207 Retrieving file information...
> 2017-11-15 09:37:52.207 PWD
< 2017-11-15 09:37:52.256 257 "/" is current directory.
> 2017-11-15 09:37:52.256 CWD /envios/00equipinterval.txt
< 2017-11-15 09:37:52.302 550 The system cannot find the file specified.
> 2017-11-15 09:37:52.303 TYPE I
< 2017-11-15 09:37:52.356 200 Type set to I.
> 2017-11-15 09:37:52.356 SIZE /envios/00equipinterval.txt
< 2017-11-15 09:37:52.404 550 The system cannot find the file specified.
. 2017-11-15 09:37:52.404 Could not retrieve file information
. 2017-11-15 09:37:52.404 Got reply 4 to the command 1024
< 2017-11-15 09:37:52.404 Script: Can't get attributes of file '00equipinterval.txt'.
< 2017-11-15 09:37:52.404 Could not retrieve file information
< 2017-11-15 09:37:52.404 The system cannot find the file specified.
. 2017-11-15 09:37:52.405 Script: Failed
. 2017-11-15 09:37:52.405 Session upkeep
. 2017-11-15 09:37:52.405 Script: Exit code: 1
. 2017-11-15 09:37:52.405 Script: Max roundtrip: 16
. 2017-11-15 09:37:52.405 Got reply 1004 to the command 1024
. 2017-11-15 09:37:52.407 Disconnected from server
lcd C:\Cindy\Temp
cd envios
get 054DlvUNLJM.*
get 054Prd*
get 054LocalVen.*
get 054SRA*
rm 054DlvUNLJM.*
rm 054Prd*
rm 054LocalVen.*
rm 054SRA*
rm 00modelequip.txt
get del*
rm del*
cd ..
