Sync Files, Copy & Delete
DWoods
United Kingdom
I have set-up a script that will synchronize remote files to a local folder, and from a local folder to remote. However, what i am wanting to do is have a script that will detect any changes in the local folder such as if a file/ folder is deleted or renamed that it will synchronize with the remote folder.
I have seen script that once the file is transferred over to the remote location it will delete the file but that is not what i am after. I wish to be able to delete the file manually through windows explorer and the script update and process the rest.
the script i am using at the moment is:
.txt file
#Resources Can be Found here - https://winscp.net/eng/docs/scripting
option batch abort
open ftp://usrname:pwd@ftp.address/
synchronize remote [local folder] /[remote folder]
.bat file
@echo off
:loop
winscp.com /script=SyncToRemote.txt
timeout /t 120
goto loop
how to synchronize files from local to remote and delete local files in winscp
I want to delete the files from local directory once i have synchronized with remote directory.
Here is my script,
option batch abort
open scp://XXX:YYY@localhost -hostkey="ZZZ"
synchronize remote -delete [local directory] [remote directory]
With the above script, files are getting deleted in remote directory.
If i use the below script, then files from remote is getting synchronized to my local.
synchronize local -delete [local directory] [remote directory]
If i switch the directory then i get an error,
synchronize local -delete [remote directory] [local directory]
