The server rejected SFTP connection, but it listens for FTP connections.
cellco
Im using built 7781. I started having this error since last winscp update.
I verified that my server uses port 22 for sftp.
I tried to connect using filezilla, which works fine
Here is the details of the problem:
It gives the following error
Did you want to use FTP protocol instead of SFTP? Prefer using encryption.
in two situations:
1. When trying to connect initially. It might give the error 20 times in a line and then allow to connect or it might connect immediately without any error.
2. When trying to transfer files. After clicking the OK button for 20-30 times files get transfered somehow
Re: The server rejected SFTP connection, but it listens for FTP connections.
Please attach a full session log file showing the problem (using the latest version of WinSCP). As well as FileZilla verbose log file (not the message log from the GUI).
If you downgrade, does the problem resolve?
HansTroost
Netherlands
same problem: The server rejected SFTP connection, but it listens for FTP connections.
Dear support,
I'm using WinSCP 5.11.3 (Build 7995) on Windows 7
Use it to connect to UBUNUTU Server 16.04 with UFW enabled: works perfect!
Try to use it for another machine, running Linux Mint 18.2 (updated!)
This machine has:
- UFW: inactive (so no firewall)
- running lighttpd for playing around with PI-Hole (so that runs as well)
- OpenSSH running
SFTP connection refused, switching to FTP did not help: similar problem. See attached LOG
  • Hans Troost-WinSCP.log (5.95 KB, Private file)
Re: same problem: The server rejected SFTP connection, but it listens for FTP connections.
HansTroost wrote:
Dear support,
This machine has:
- OpenSSH running
Can you connect with any other SFTP or FTP client?
HansTroost
Netherlands
First of all: Happy 2018! And thanks for replying.
Followed your suggestion: with other tools: similar problems.
Possibly my OpenSSH-server-installation was not configured well or something else. Re-installed it and now everything works fine.
My apologies for asking before I tried everything else: I'm relatively new to all this stuff: have end-user experience with linux, but now since some weeks experimenting with setting up web-servers on linux, configuring firewalls etc.
Erik_Nguyen
I have to login to give my thanks to you. You help me out a lot when I get lost. Thanks so much, bro.
ashamide
Please remember to do this on the ubuntu server
sudo apt install openssh-server
