Weird error about files not existing
youradds
UK
I'm on the latest release candidate of WinSCP , and I've started getting weird error messages:
https://ibb.co/T0czt4w
https://ibb.co/0jrNvLn
It seems to randomly come up - and I'm not sure why (I finished saving those files ages ago, and it all works fine - then randomly these errors come up)
Any ideas? Is anyone else having this problem?
Cheers
Andy[/img]
Re: Weird error about files not existing
When are you getting those errors? Download? Upload?
youradds
UK
Hi Martin,
I have enabled logging, and will check it one it comes up again (I can't find any real reason to it, as it seems to randomly occur)
Andy
youradds
UK
Here we go. It seemed to do it after I had WinSCP open with a connection, and then left it to go out. When I came back, I had the messages.
Andy
  • ftp-test.log (119.09 KB, Private file)
youradds
UK
BTW as a bit more info. I just had it happen again. I got this error:
https://ibb.co/zbFwczk
And the reason its getting that error, is because I don't have that file open any more (it was closed ages ago);
https://ibb.co/BqWc2gs
So the issues seems to be around it trying to upload files that were closed a while back... but I'm not sure why?
Here is what the transfer log shows:
https://ibb.co/nsCry4p
Cheers
Andy
