"Tag chmod before tag download" exception
Dziki_Jam
Belarus, Minsk
Hello! I'm getting the following exception when executing directory sync with permissions set:
Exception calling "SynchronizeDirectories" with "7" argument(s): "Tag chmod before tag download"
The most strange thing here is that script does its job and files are transferred correctly as far as I can judge. Even permissions are correct.
Here's my script's main part code:
try {
        Protocol                             = [WinSCP.Protocol]::Sftp
        HostName                             = $PuppetSrvIP
        UserName                             = $PuppetSrvUserName
        GiveUpSecurityAndAcceptAnySshHostKey = $True
        SshPrivateKeyPath                    = $PuppetSrvKeyFile
        #SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
    $transferOptions.FileMask = "$($Include -join ";")|$($Exclude -join ";")"
    $transferOptions.FilePermissions = New-Object WinSCP.FilePermissions
    $transferOptions.FilePermissions.Octal = "$Permissions"
    try {
        # Will continuously report progress of synchronization
        $session.add_FileTransferred( { FileTransferred($_) } )
        # Connect
        if ($NoCleanup) {
            $Cleanup = $False
        else {
            $Cleanup = $True
        # Synchronize files
        $synchronizationResult = $session.SynchronizeDirectories(
         [WinSCP.SynchronizationMode]::Remote, $SourcePath, $TargetPath, $Cleanup, $False, [WinSCP.SynchronizationCriteria]::Time, $transferOptions)
        # Throw on any error
        $synchronizationResult.Check()
    finally {
        # Disconnect, clean up
        $session.Dispose()
    Write-Host "Successfully synced directories"
    if ($NoCleanup) {
        Write-Host "No cleanup was performed"
catch {
    $Exception = $_.Exception
    Write-Error "Error: $($Exception.Message)"
How can I debug this strange behavior? I've checked session logs but nothing suspicious was found except the same exception.
Also, I've noticed that FileTransferred event handler stopped working after I added FilePermissions option. I'm using event handler from this example.
Re: "Tag chmod before tag download" exception
Please set Session.DebugLogPath and Session.SessionLogPath and attach both logs.
Thanks for the logs.
Issue 1603 – Failure when processing results of upload during synchronization in .NET assembly when a directory was created with explicitly set permissions as the first operation
