WinSCP is coping old versions of files that have been updated externally on remote server
dascjo
Version WinSCP 5.13, Windows 10. Recently upgraded to this version and noticed it. SFTP protocol. Using Commander GUI.
I have seen this several times on 5.13. To repeat:
1. In WinSCP, display a directory with files on the server. Pick a file(s) and copy to your PC.
2. External to WinSCP, change (edit) the file(s), like through a putty session or something.
3. Back to WinSCP, copy the file(s) locally to your PC.
4. The file(s) copied are the old versions before the changes. Granted, the time stamp in the WinSCP commander window still shows the old time stamp for the remote file. But in previous versions of winSCP the updated file(s) were still copied. That does not appear to be the case, as if WinSCP has cached the file(s) or something.
5. Now, if you do a 'refresh' on the files in the WinSCP remote Commander so their time stamps update, THEN copy the files as in step 3, the correct update file is copied.
Re: WinSCP is coping old versions of files that have been updated externally on remote server
WinSCP does not cache file contents.
liverpoolfcfan
The problem appears to be that when you double-click on the remote file to download it again, the remote tree is not refreshed, and the copy stops at whatever file length is currently shown in the remote tree view.
I have seen this behaviour where I have logs that are constantly being appended to. It used to be that every time I double-clicked on the remote file it would download whatever the latest updated file state was - regardless of how much longer the file had gotten.
This did confuse the % complete meter - as it would reach 100% way before the file completed downloading.
However, it did not prevent the latest file updates from downloading.
In this latest version the copy appears to just stop at whatever byte count the remote tree has for the file.
If I click the refresh button on the remote tree, I can see the file length get refreshed to a larger size, and if I then double-click on it the latest contents will download correctly.
I hope this helps
WinSCP does not use a "listed" size of a file for a download.
Please attach the log.
