How to configure WinSCP to use specific mac-algorithm?
jwessling
Seattle
We have an business partner that would like us to use the following when uploading files to there SFTP site:
  1. Cipher = aes256-ctr
  2. MAC algorithm = hmac-sha256
We can specify the cipher in WinSCP easy enough, but haven't determined how or if we can specify the MAC algorithm to be used. We can see from the logs that hmac-sha1 is currently being used. Does anyone know how the MAC algorithm can be specified in WinSCP?
Thank you,
Jeff
Re: How to configure WinSCP to use specific mac-algorithm?
There's no configuration option for that. Though WinSCP should always favor HMAC-SHA-256, if available. Please attach a full session log file showing the problem (using the latest version of WinSCP).
Thanks Martin, here's what I've got. It looks like
Doing Diffie-Hellman key exchange with hash SHA-256
but then later the logs indicate
Initialised HMAC-SHA1 client->server MAC algorithm
. 2018-03-16 12:45:40.700 Looking up host "[REDACTED]"
. 2018-03-16 12:45:40.700 Connecting to [REDACTED] port 22
. 2018-03-16 12:45:40.779 Server version: SSH-2.0-SSHD
. 2018-03-16 12:45:40.779 Using SSH protocol version 2
. 2018-03-16 12:45:40.779 We claim version: SSH-2.0-WinSCP_release_5.7.7
. 2018-03-16 12:45:40.825 Doing Diffie-Hellman group exchange
. 2018-03-16 12:45:41.028 Doing Diffie-Hellman key exchange with hash SHA-256
. 2018-03-16 12:45:42.654 Verifying host key rsa2 [REDACTED]
. 2018-03-16 12:45:42.700 Host key matches cached key
. 2018-03-16 12:45:42.700 Host key fingerprint is:
. 2018-03-16 12:45:42.700 ssh-rsa 2048 [REDACTED]
. 2018-03-16 12:45:42.700 Initialised AES-256 SDCTR client->server encryption
. 2018-03-16 12:45:42.700 Initialised HMAC-SHA1 client->server MAC algorithm
. 2018-03-16 12:45:42.700 Initialised AES-256 SDCTR server->client encryption
. 2018-03-16 12:45:42.700 Initialised HMAC-SHA1 server->client MAC algorithm
Are you sure the server even supports HMAC-SHA-256? Can you connect with HMAC-SHA-256 using any other SSH/SFTP client?
