WinSCP FTP TLS/SSL timeout error
csparkman65@...
I'm attempting to use WinSCP to FTP data to a support website. It was working some weeks ago, but I just discovered it has stopped working. I'm unsure what may have changed. I using WinSCP on a Window10 Laptop. WinSCP version 5.13 (build 8172).
The error that I'm seeing:
Using TLSv1.2, cipher TLSv1/SSLv3: AES128-SHA, 2048 bit RSA, AES128-SHA SSLv3 Kx=RSA Au=RSA Enc=AES(128) Mac=SHA1
Timeout detected. (control connection)
Connection failed.
Description: The attached is a screen recording of my issue.
Re: WinSCP FTP TLS/SSL timeout error
Also, can you connect using any other FTP client?
