Automating file transfer in Windows format
Daleritf
I am transferring files on a scheduled bases using these commands:
# the script on errors
option batch continue
# Connectto the FTP Site
open sftp://username:password@hostname
# Change Directory
cd /Production/FolderName/
# Transfer all the .tif files in this directory
put D:\LocalFolderName\*.txt -nopermissions -nopreservetime
# Disconnect from the FTP site.
close
Files are getting transferred without a problem but they are converted to Unix format. Server where I am copying these files does not support Unix format. What should I add to my script to transfer files in Windows format?
Re: Automating file transfer in Windows format
WinSCP does not convert file format by default. Unless you have changed transfer mode in global configuration (in GUI).
Ideally you should isolate the script from GUI configuration using /ini=nul command-line switch.
https://winscp.net/eng/docs/scripting#configuration
Or force the binary mode using -transfer=binary switch of the put command:
https://winscp.net/eng/docs/scriptcommand_put#transfer
