can not create remote file: ... path.. filename.filepart - permission denied error
techie_nas
hi there, I am keep getting this error for just one file. I am using WinSCP 4.3.4.When I transfer the file to remote directory, I get following error:
Can not create remote file: '..pathtofile/filename.filepart'.
Permission denied.
Error code: 3
Error message from server: Permission denied
Request code: 3
I have full access to remote directory and this file as well.Permission for this file is set to 777. I am able to transfer all other files but just this one file is not working. I did try removing transfer resuming checkbox but it did not work. I wonder if throws error for filepart, is there a way to clean up all temp/partial files? I tried removing clear caches from commands but it did not fix the error.
I need to change this file a lot so it is becoming annoying problem. Currently I transfer this file to another temp directory and then move it to folder when I need to move it to.
Thank you for your help.
Re: can not create remote file: ... path.. filename.filepart - permission denied error
Try again. Maybe you didn't set the option correctly. If you did, you would not get an error with .filepart.
And you urgently need to upgrade your installation of WinSCP.
techie_nas
I tried again but the same error. Strange thing is only one file throws error, all others are working fine. If I upgrade the version then it does not work with my VPN and remote network.
Please help.
Thanks.
Please help.
Thanks.
Why?
