synchronize remote all files allways
untouchable
Switzerland
Hi there
Im searching a script that synchronizes my remote files no matter what timestamp, or anything. All files should be synchronized from local to remote no matter if they allready exist or not (create new files or overwrite existing files).
I've tried with that script:
synchronize remote -criteria=none -filemask="PDS_STRUB*.|*/" "\\STRUBAD01\AlteDaten\Produktedokumentation\Datenblätter\deutsch\01 Motorenoele" "/share/CACHEDEV1_DATA/STRUB-Data/Deutsch/01 Motorenoele/01 Datenblätter"
but in log there is a entry "exluded from synchronization". How do I have to do this?
  • WinSCP.zip (231.78 KB, Private file)
Description: Log File
Re: synchronize remote all files allways
What you want is not a synchronization. It's a dumb upload.
So use put command:
put -filemask="PDS_STRUB*.|*/" "\\STRUBAD01\AlteDaten\Produktedokumentation\Datenblätter\deutsch\01 Motorenoele\*" "/share/CACHEDEV1_DATA/STRUB-Data/Deutsch/01 Motorenoele/01 Datenblätter/"
https://winscp.net/eng/docs/scriptcommand_put
untouchable
Switzerland
So use put command:
Hi, tried that but still not working. This is the script i'm using.
option batch on
open sftp://xxxx:xxxxxxx/ -hostkey="ssh-rsa 2048 xxxxxxxxxxxxxxxxxxxx
# Synchronisation der Datenblätter
Still got excluded from Transfer in log. Could it be a Problem because files allready exists?
thx
Andreas
  • WinSCP.zip (83.06 KB, Private file)
Description: Logfile
All the files that got excluded were excluded rightly, as they do not match the file mask.
So you probably have the filemask wrong.
But I cannot know what files you actually want to transfer.
Maybe you wanted PDS_STRUB*.* instead of PDS_STRUB*.?
