BUG REPORT: Duplicate option copies directories incorrectly [does not overwrite existing directory]
NewUser1
Europe/London
Example of error:
WinSCP on Windows 7 SP1 (all latest Updates), WinSCP version 5.13.2 (Build 8455).
2 directories '/mnt/usb-data/entware/lib/' & '/mnt/usb-data/entware/[BACKUP]-lib/'
Want to copy contents of '/mnt/usb-data/entware/lib/' to '/mnt/usb-data/entware/[BACKUP]-lib/'.
Target directory already has files & directory structure from previous duplicate action.
When the files/dirs are duplicated the files copy to the correct place and overwrite the existing files but the directory tree ('opkg/' in this instance) is copied within the existing 'opkg' directory
[See Screen captures]
Steps to recreate:
Navigate Directory tree to '/mnt/usb-data/entware/lib/' and select all files/Directories using left click & drag down.
Right click on selection and click 'Duplicate' [Same as Shift-F5]
Set Target Remote Path: to '/mnt/usb-data/entware/[BACKUP]-lib/'
Click OK.
Files/Dirs are copied to 'target remote path:'.
When the '/mnt/usb-data/entware/[BACKUP]-lib/' tree is selected/refreshed the 'opkg' directory contains the new copy of the 'opkg' directory instead of being overwritten.
All other files are overwritten as expected.
Description: Before / Duplicate command / After performing Duplicate command / WinSCP Version
NewUser1
Europe/London
Please could this be moved to userid 'NewUser1'
For some reason I could not post this on my new account 'NewUser1'!!!???
I posted it as 'NewUser2', if possible could you change the ID so I get the replies sent to the correct user.
NewUser2 does not exist as a account.
Thanks.
Re: BUG REPORT: Duplicate option copies directories incorrectly [does not overwrite existing directory]
Thanks for your report. What protocol are you using?
NewUser1
Europe/London
Session Log for Error.
Protocol info as follows from top of log file:
 2018-05-25 19:10:39.929 Tunnel: No
. 2018-05-25 19:10:39.929 Transfer Protocol: SCP
. 2018-05-25 19:10:39.929 Ping type: Null, Ping interval: 20 sec; Timeout: 30 sec
. 2018-05-25 19:10:39.929 Disable Nagle: No
. 2018-05-25 19:10:39.929 Proxy: None
. 2018-05-25 19:10:39.929 Send buffer: 262144
. 2018-05-25 19:10:39.929 SSH protocol version: 2; Compression: Yes
. 2018-05-25 19:10:39.929 Bypass authentication: No
. 2018-05-25 19:10:39.929 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: Yes
. 2018-05-25 19:10:39.929 GSSAPI: Forwarding: Yes; Libs: gssapi32,sspi,custom; Custom:
. 2018-05-25 19:10:39.929 Ciphers: aes,blowfish,3des,chacha20,WARN,arcfour,des; Ssh2DES: No
. 2018-05-25 19:10:39.929 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,dh-group1-sha1,rsa,WARN
. 2018-05-25 19:10:39.929 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2018-05-25 19:10:39.929 Simple channel: Yes
. 2018-05-25 19:10:39.929 Return code variable: Autodetect; Lookup user groups: Auto
. 2018-05-25 19:10:39.929 Shell: default
. 2018-05-25 19:10:39.929 EOL: LF, UTF: Auto
. 2018-05-25 19:10:39.929 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: Yes
. 2018-05-25 19:10:39.929 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2018-05-25 19:10:39.929 Local directory: C:\Downloads, Remote directory: /jffs, Update: Yes, Cache: Yes
. 2018-05-25 19:10:39.929 Cache directory changes: Yes, Permanent: Yes
. 2018-05-25 19:10:39.929 Recycle bin: Delete to: Yes, Overwritten to: No, Bin path: /tmp
. 2018-05-25 19:10:39.929 DST mode: Unix;Timezone offset: 0h 0m
The copy of 'opkg' starts at line 8629
I marked it with:
# STARTS COPYING 'opkg' HERE ====>
Attached .zip file marked as 'Private File'.
Many thanks for your help.
  • Asus-Router-(sftp)[duplicate].zip (136.15 KB, Private file)
Description: Removed some data such as passwords IP Addresses etc
Re: Session Log for Error.
Sorry for my late answer. Though I cannot reproduce the problem on a standard Linux server with a bash shell. What is your server like? What shell are you using?
NewUser1
Europe/London
Thanks for your response.
It is an ASUS Router RT-AC56U running an ash shell (Busybox).
[ash & sh are the same 'busybox' binary]
uname -a gives:
'Linux RT-AC56U 2.6.36.4brcmarm #1 SMP PREEMPT Sat May 12 22:03:01 EDT 2018 armv7l ASUSWRT-Merlin'
I would expect ash/sh & bash to work the same way for a file copy !!!
To eliminate ash vs bash:
Installed bash version [GNU bash, version 4.4.18(1)-release-(arm-openwrt-linux-gnu)]
Set the shell to '/mnt/usb-data/entware/bin/bash' in WinSCP.
Tried same steps and the problem repeated itself exactly the same result.
Tried running 'cp' command to replicate steps.
Ran the following multiple times under the 'bash' & 'ash' shell:
cp -r /mnt/usb-data/entware/lib/* /mnt/usb-data/entware/[Backup]-lib/
Files & directories copied as expected .... overwriting the previous files & directories.
Problem looks to me like it is something that WinSCP is doing, unless I am missing something !!!???
Additional Note:
Tried older version of WinSCP Ver 5.9.5 and it also has the same problem.
WinSCP does this:
cp -p -r -f -T "opkg" "/mnt/usb-data/entware/[BACKUP]-lib/opkg"
Can you test it?
NewUser1
Europe/London
WinSCP does this:
Can you test it?
The cp command on the Router does not have a -T flag.
Could that be the problem ?
Without the -T flag I get:
User@56U:/tmp/mnt/usb-data/entware/lib# cp -p -r -f "opkg" "/mnt/usb-data/entware/[Backup\]-lib/opkg"
cp: can't create directory '/mnt/usb-data/entware/[Backup\]-lib/opkg': No such file or directory
Googled Man Page for cp and got:
-T, --no-target-directory
    treat DEST as a normal file
Sorry, not sure what the -T flag is supposed to do when destination is a Directory !!!???
NewUser1
Europe/London
Solved the problem with a 'Workaround'
I took the hint from the 'missing flag on cp' and installed just 'cp' from the coreutils package.
[opkg install coreutils-cp] <--- Installation command for Routers Firmware.
I now have a cp command that has all the flags and the 'Duplicate problem' is solved.
Files copy as they should.
Interesting that 'cp -r' using the original 'Busybox' cp works BUT with all the flags (while missing -T) did not !!!???
As it is not WinSCP that is the problem, probably need to include a note that non-GNU or 'busybox' derived commands may be incompatible with WinSCP.
Many thanks for your time & help in solving this.
NewUser1
Europe/London
Alternative Solution
Problem has been replicated & confirmed by another WinSCP user on an ASUS Router running the same firmware.*
Found alternative solution that requires NO new s/w or install.
*https://www.snbforums.com/threads/fyi-winscp-may-work-incorrectly-when-using-the-standard-busybox-cp.47311/#post-412881
If you tick the "Duplicate via local temporary copy" box the problem doesn't occur.
Seems odd that the temporary copy makes a difference !!!???
Can only assume that the 'Temporary copy' method uses a different 'cp' commandline !!!???
There is now a simple solution that you may need to document if others have the problem.
As you will know Busybox is used in a lot of kit, so problem may be more common than it initially appears. i.e. they will all have cp without '-T flag'.
Apparently, it is also missing from BSD's native 'cp' as well.
Also I have beeen advised that it is not posix compliant, ref Opengroup base spec here:
cp -T (no target directory) is part of GNU's coreutils package, but the -T flag itself is outside of posix....
https://pubs.opengroup.org/onlinepubs/9699919799/utilities/cp.html#tag_20_24
Problem Solved via 2 methods ...... thanks again for you help.
