WinSCP 5.14 Beta
martinc
WinSCP 5.14 Beta
I am currently building a class library in .Net Standard 2.0 and would like to try using WinSCP 5.14. Could you send me a link to do download the beta? Thank you
Reply with quote E-mail
Pyre909
Utah
Beta test for Old System
Hi Martin,
I am updating software on an old system. Can you send me the beta for 5.14 for testing in order to update once its released?
Regards!
Re: Beta test for Old System
What exactly do you want? Do you also want a .NET Standard build of .NET assembly?
Re: Beta Download of 5.14
aperiooculus wrote:
I am upgrading a project to NetStandard 2.0. May I get a beta download?
Hi Martin,
Yes that is correct for the .NET Standard build that I am wanting to test for a project I have been updating.
Thanks!
OK, sent.
jsteeleATsaxony wrote:
Hello Martin - May I also please have access to the new beta?
Thank you!
Justin
Sent.
Re: Pre-Release 5.14
kyndallt wrote:
Can I get a link to the Pre-Release build for the 5.14 version.
Thank you..
Sent. Thanks for your donation.
Re: 5.14
priyar wrote:
Please send me pre-release version 5.14 as I would like to try it in .NET Standard.
Sent.
k3davis
If I could get a beta copy of the netstandard build of the .net assembly, I would greatly appreciate it (unless the public release is imminent). Thanks for all your labors!
erol
Bosnia & Herzegovina
Martin could you be so kind to share 5.14 beta link with me also. I would like to test it because of Bug 133 being resolved in this version.
Thank you.
Sent.
detonazione
Sent.
Hi Martin, I would appreciate if I could have a link to test the beta. I'm having issues with an S3 compatible bucket (it's a Minio server): I get always a "XMLParseFailure" error as soon as I try to access the bucket. This might be related to https://winscp.net/forum/viewtopic.php?t=25903
Cheers.
wilk321
Ctrl+C Ctrl+T Download shortcut
Hi all,
Does anyone know why there was a change in this shourtcut?
And more important how to change it back to Ctr+C for Download? (other that installing older version)
For me Ctrl+C was way quicker :)
Re: Ctrl+C Ctrl+T Download shortcut
Because Ctrl+C now copies the file to the clipboard, just as in any other Windows application. There's no option to change it back.
