Default Transfer = Binary transferring as text after OS upgrade.
raulblack
Olympia, WA
I recently built a new server (OS = Windows Server 2016) and installed WinSCP with the same version and settings as the old server (OS = Windows Server 2008). However, the old server properly transfers text files in Binary. I believe the new server is transferring text files as TEXT. I'm using Version 5.9.6 (Build 7601). The files are going between a folder on the local drive to a secure SFTP site on the network.
Notice the extra CR in line 906 of the file transferred on the new server that's not there on the old server. Have you any ideas about why this might be happening?
Thanks!
raulblack
Re: Default Transfer = Binary transferring as text after OS upgrade.
I should add that when I put -transfer = binary in the script that moves the file on the new server, the problem goes away. If I leave it out, I get the extra CR that causes a blank line.
