https vs davs
Kleo
https vs davs
For what reason in new versions is changed from https to davs at "Generate file URL" dialog for WebDAV protocol?
Sometimes it is necessary to copy links from here, and for example paste to another Download Managers. And each time have to manually rename the prefix, because they don't understand davs. Is it really necessary, or better return as it was before?
Kleo
But in this case, it may be appropriate to add a switch to display all links with https:// instead. Or simultaneously generate both formats in separate columns / spots within this dialog.
Anyway, Thanks for Your Great Work and Best for my needs WebDAV Manager!
Kleo
Yes, it works as expected with http:// prefix.
Thanks so Much!
Lately, I found an Generate HTTP URL extension, which fits for similar purposes when not needed username & pass included in url:
https://winscp.net/eng/docs/extension_generate_http_url
May someone would come in handy.
A few useful Cloud Storages with WebDAV access:
MyDrive.ch (Switzerland) : 100 MB for free
https://www.mydrive.ch/ (https://webdav.mydrive.ch/)
CloudMe.com (Sweden) : 3-16 GB for free
https://www.cloudme.com/ (https://webdav.cloudme.com/username)
PowerFolder.com (Germany) : 5 GB for free
https://www.powerfolder.com/ (https://my.powerfolder.com/webdav/)
OpenDrive.com (USA) : 5 GB for free
https://www.opendrive.com/ (https://webdav.opendrive.com)
HiDrive (Germany) : 5-10 GB for free
https://www.free-hidrive.com/ (https://username.webdav.hidrive.strato.com)
DriveOnWeb.de (Germany) : 5 GB for free
https://www.driveonweb.de/ (https://storage.driveonweb.de/probdav)
MagentaCloud.de (Germany) : 10 GB for free
https://www.magentacloud.de/ (https://webdav.magentacloud.de)
pCloud.com (Switzerland) : 10-20 GB for free
https://www.pcloud.com/ (https://webdav.pcloud.com/)
Box.com : 10 GB for free
https://www.box.com/ (https://dav.box.com/dav)
4shared.com : 15 GB for free
https://www.4shared.com/ (https://webdav.4shared.com/)
Allsync.com (Netherlands) : 50 GB for free
https://allsync.com/ (https://cloud.allsync.com/remote.php/webdav/)
ADrive.com (USA) : FREE 60-day trial (no credit card required)
All type of protocols: FTP(s), SFTP, WebDAV, SCP - well for testing
Good Luck
