Rename shouldn't be an option for S3 folders
taras
WinSCP v5.13.3 Build 8565
Windows 10 v1803
Using Explorer-style GUI
When I try to rename any folder in an S3 bucket, I get the error: "Direct duplication of folders is not supported. Use a duplication via a local temporary copy." This is because you can't rename folders in S3. I guess WinSCP needs to hide/disable the rename option for S3 folders (or improve the error message).
