Two-factor authentication
aruhela
Hi Support Team,
The issue is regarding two-factor authentication. I am able to login on my web server by just providing the token key with an already stored password. However, whenever I edit the first file opened from the WinSCP explorer and save it, WinSCP asks for authentication again. At this time, WinSCP asks for both password and token.
This bug is very similar to "Minor problem with ssh google two-factor authentication". I am attaching the debug logs for your reference.
Thanks and Regards,
Amit Ruhela
  • server1.log (576.58 KB, Private file)
Description: A few information like server name and IP address are changed in this file. If there are any other sensitive texts like ssh keys in this attachment, please let me know or delete it on your server file.
Re: Two-factor authentication
And what is the expected behavior? Do you expect no prompt at all (reusing password and token)? Or is the token one-time only, and you expect no password prompt, but you need a token prompt for a new token?
aruhela
Since a user has already logged in to the remote server, therefore, I expect WinSCP not to ask the authentication again while doing file modification. If not possible for some reason, then, for the ease of users, WinSCP should use the already stored password and only ask for the token to be entered.
WinSCP never asks for second time authentication until all files are only read. Only, when a file is modified, it requests for second time authentication. Once credentials are verified, one can modify several files without any further authentications.
Files saved in an editor are put to a transfer queue for an upload. The queue (must) uses a different connection, so it needs a new authentication. WinSCP actually remembers the token (assuming it's a password) and re-tries it for the authentication. That fails (I assume the token is one-time only) and WinSCP restarts the authentication from the scratch, not using a stored password, as it does not know what caused failed authentication (which of the two "passwords"). Try turning off Remember password for duration of the session:
https://winscp.net/eng/docs/ui_pref_security
aruhela
Thanks, Martin for the information and the suggestion.
Is it possible to create both the connections beforehand (at the time of first connection creation)?
Amit
@aruhela: No. Would that even help? I understood that you need a separate token for each. So you would still have to type a token twice. And you would possibly even not know, which token belongs to which connection, right?
aruhela
Hi Martin,
Several times, I have opened two windows (one PuTTY and another WinSCP) using the same token. It depends upon how fast you enter the token which remains the same for about 30 seconds. I believe it is possible to open two sessions in the background within WinSCP using the same token. if you can generate a temporary executable, I can give it a try.
Amit
aruhela
Thanks, Martin for the quick fix. I really appreciate your efforts.
Is it possible to download the development version? If yes, can you point me the weblink?
Amit
CallumWalley
Auckland
Create background queue connection right after session starts
Hello there,
You mention in [url*]https://winscp.net/tracker/1681[/url] that the simultaneous creation of the background queue could be enabled with a hidden setting somewhere.
Is there anywhere I could find instruction on how to do this?
This is something I have wanted to do for a very long time.
Reply with quote E-mail
kstopka3
Is it possible to still set this up?
I would also like to simultaneously create this background queue but I do not see the Interface\QueueBootstrap=1 option at the link above, nor could I find any way to enable this in the preferences window. Is it possible to enable this? Thank you in advance.
Best regards,
Kris
kstopka3
Re: Is it possible to still set this up?
Hi Martin,
Thank you for your response. I am not very familiar with this type of syntax, unfortunately, and I am unsure how to implement this. I saw that I could choose "Automatic INI file" under the storage option but this file gets overwritten when changes are made to it (i.e., when I do something in WinSCP like close the program). Could you please tell me exactly how I would go about making a change to the Windows registry (step by step)? Thank you in advance.
Best regards,
Kris
@kstopka3: You will find zillions of articles/videos online on changing Windows registry.
And as you already know how to get the INI file: Well, just close WinSCP before you make the changes to the INI file!
