S3 Transfer Automation > The specified bucket does not exist
blackbishop313
I'm trying to use WinSCPnet to upload files to S3 using script task in SSIS.
This is my code (using Winscp version 5.14.1.beta) :
// Set up session options
    Protocol = Protocol.S3,
    HostName = "<bucketName>.s3-eu-west-1.amazonaws.com",
    UserName = "*****************",
    Password = "***************************",
    session.Open(sessionOptions);
    //logic here
The session is established but when I try tu put files I get this error :
Here's my code :
string  LocalDirectoryPath = "C:\path\to\file";
string  RemoteDirectoryPath = "/<BucketName>/";
bool    DeleteSourceFiles = false;
TransferOptions transferOptions = new TransferOptions();
session.PutFiles(LocalDirectoryPath, RemoteDirectoryPath, DeleteSourceFiles, transferOptions);
When I change RemoteDirectoryPath to "/" I get another error :
WinSCP.SessionRemoteException: Copying files to remote side failed. Specify target bucket
In the WinSCP UI I have the same behaviour. If I use the following configuration it works :
HostName = "s3-eu-west-1.amazonaws.com"
Remote directory = "/<bucketName>"
But if I use :
Remote directory = "/"
And try to drag some file I get this error :
Could you please take a look at this ? Thank's
The logs generated by WinSCP :
Description: logs generated by Winscp
Re: S3 Transfer Automation > The specified bucket does not exist
This is the correct solution. So use it in .NET assembly too.
blackbishop
Paris
Thank you for your reply.
I could not find the equivalent "Initial Remote Directory" in the .NET assembly.
If I try to connect using only :
I get this error :
WinSCP.SessionRemoteException: Access denied. Access Denied Extra Details: RequestId: 280C45C8BB312493, HostId: plUn**************rMlQA/pN************CEc/LR8******= Connection failed
With UI this is set in Advanced Site Settings dialog (https://winscp.net/eng/docs/ui_login_directories)
How could one do the same with the assembly code?
You already specify your bucket name in RemoteDirectoryPath that you pass to Session.PutFiles. That should be enough.
If that does not work, please attach a full session log file showing the problem (using the latest version of WinSCP).
blackbishop
Paris
No, it is not enough because the connection isn't even established.
The error occurs when I call session.Open(sessionOptions);, so before the Session.PutFiles is executed.
The same happens in the UI ; if I do not specify initial remote directory I get the same error.
I tried to use <bucketName>.s3-eu-west-1.amazonaws.com to bypass that behaviour but it resulted in another weird behaviour which is explained in the first post.
Here's the session log generated by WinSCP 5.14.1 beta :
Description: full session log file showing the problem
Sorry, but I got lost. You wrote before:
So does it work or not? Or does it work partially only? Can you elaborate?
Anyway, try this:
sessionOptions.AddRawSettings("RemoteDirectory", "/bucket");
See https://winscp.net/eng/docs/faq_script_vs_gui
blackbishop
Paris
Sorry if I haven't give good explanation of the problem.
IN WinSCP UI
Working configuration : Everything works fine (connection and files transfer)
Initial Remote directory = "/<bucketName>"
Not working configuration :
The connection works but error occurs when I try to put files
Initial Remote directory = "/"
IN .NET ASSEMBLY
The connection is established correctly but when the PutFiles is executed it generates an exception.
I tried sessionOptions.AddRawSettings("RemoteDirectory", "/bucket"); but with no success too.
    HostName = "s3-eu-west-1.amazonaws.com",
sessionOptions.AddRawSettings("RemoteDirectory", "/<bucketName>");
    session.PutFiles(LocalDirectoryPath, "/", DeleteSourceFiles, transferOptions);
Hope this is clear for you.
Thank you for your help.
blackbishop
Paris
I finally got it to work by changing this ligne :
with this one :
session.PutFiles(LocalDirectoryPath, "*", DeleteSourceFiles, transferOptions);
The * did the trick.
So it's OK for sessionOptions.AddRawSettings("RemoteDirectory", "/bucketName");
Thank you :)
blackbishop wrote:
IN .NET ASSEMBLY
with this one :
session.PutFiles(LocalDirectoryPath, "/bucketName/*", DeleteSourceFiles, transferOptions);
Are you sure it's the * that "did the trick"? It should work even without the *:
session.PutFiles(LocalDirectoryPath, "/bucketName/", DeleteSourceFiles, transferOptions);
blackbishop
Paris
Sorry I meant :
Anyway this also works fine (just tested it):
The only one that doesn't work is when using "/" as remote directory in the PutFiles method.
You cannot upload to root folder on S3.
