Overwriting without confirmation
Georg
Using WinSCP 5.13.5 (Build 8967) with default preferences except "Maximal number of transfers at the same time" set to "1".
I selected many files on my ftp server.
I started to "download and delete (F6)" these files to my local disk in the Background (queue1).
This background process was still in progress when I refreshed the ftp directory and selected new files to "download and delete (F6)" (queue2).
Accidently I selected some files from queue1 again so that these files were also in queue2.
When queue2 is processing such an already moved file it displays an error message that it can't open the source file.
Bug: At this time the target file is already overwritten with a zero bytes file.
Re: Overwriting without confirmation
Can you reproduce the problem?
I believe this should happen only if you instruct WinSCP to download very same file at the very same moment, not when "processing such an already moved file".
Georg
After skipping the 3 files were overwritten and now the size is 0 Bytes:
Dateiname                                                            Größe           Geändert   Typ                    BeschreibungBildeigenschaften
A2 - Abenteuer Autobahn 2018-12-10 19-10.rec                             0   11.12.2018 09:57   REC Video File (VLC)
A2 - Abenteuer Autobahn 2018-12-10 19-10.rec.inf                         0   11.12.2018 09:57   Setup-Informationen
A2 - Abenteuer Autobahn 2018-12-10 19-10.rec.nav                         0   11.12.2018 09:57   NAV-Datei
Callin' Mr. Brain 2018-12-11 03-40.rec                       4.230.151.872   11.12.2018 00:00   REC Video File (VLC)
Callin' Mr. Brain 2018-12-11 03-40.rec.inf                           3.316   11.12.2018 00:00   Setup-Informationen
Callin' Mr. Brain 2018-12-11 03-40.rec.nav                      11.520.064   11.12.2018 00:00   NAV-Datei
