PowerShell Help: Delete local files after sync
Sundance
Dear WinSCP-users,
i'm currently trying to find a way to sync the contents of a local folder to a remote folder and delete the local files after a successful transfer.
I found this PowerShell script, but it does it the other way round..
https://winscp.net/eng/docs/library_example_delete_after_successful_download
I'm unfortunately not a PowerShell expert so i'm having difficulties understanding what i need to change.
I changed the SynchonizationMode and the sync works when i execute the script. But the deletion won't work and i don't know what to change.
Any help is greatly appreciated :)
Thanks in advance
Sundance
Sundance
I figured that using the put command with -delete, this gets much easier. The only thing that doesn't seem to work, is syncing ALL files AND folders within the local folder, without deleting the local folder itself.
I'm currently using this command in a bat script:
put -delete -filemask=*/ X:\(LocalPath)\ /(RemotePath)"^
It syncs fine, but deletes the LocalPath folder. I can't seem to find a filemask that works. Using *.* doesn't sync the first folder within the localpath, but only it's subfolders.
THanks in advance for any help!
Sundance
jkn
GER
hi,
similar problem
    "get /imp -filemask=*.txt \pfad\imp" ^
    "rm /imp *.txt" ^
deletes the whole /imp folder?
    "rm /imp/ *.txt" ^
works so far with a note in the logfile that the slash isn´t clearly.
jkn
GER
Hello again
    "rm /IN/*.txt" ^
deletes *.txt without the note and doesn't delete the /IN directory
Works fine - thx
I'm not sure I understand your problem fully, but maybe you are looking for this:
put -delete -filemask=*/ X:\(LocalPath)\* /(RemotePath)/" ^
