winscp script returning error level 1 after successful transfer
mdb74
Australia
The following code returns an %ERRORLEBVEL% 1 even though the log files indicate that the script exited with code 0. Why would this be the case?
"C:\Program Files (x86)\WinSCP\WinSCP.exe" /log="C:\temp\WinSCP.log" /ini=nul /script="C:\temp\winscp.txt -resumesupport"
echo %ERRORLEVEL%
pause
 open ......
lcd F:\AssetWatch\Data
cd /
put *.xml
close
> 2019-01-15 19:04:27.747 Script: put *.xml
. 2019-01-15 19:04:27.753 Copying 2 files/directories to remote directory "/" - total size: 580,406
. 2019-01-15 19:04:27.753   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2019-01-15 19:04:27.753   TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: ; ResumeL: 0
. 2019-01-15 19:04:27.753   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2019-01-15 19:04:27.753 Getting real path for '/'
> 2019-01-15 19:04:27.753 Type: SSH_FXP_REALPATH, Size: 10, Number: 784
< 2019-01-15 19:04:27.767 Type: SSH_FXP_NAME, Size: 23, Number: 784
. 2019-01-15 19:04:27.767 Real path is '/'
. 2019-01-15 19:04:27.767 File: 'testSFTP1.xml' [2019-01-14T08:43:45.555Z] [290203]
. 2019-01-15 19:04:27.767 Copying "testSFTP1.xml" to remote directory started.
. 2019-01-15 19:04:27.767 Binary transfer mode selected.
. 2019-01-15 19:04:27.767 Checking existence of file.
> 2019-01-15 19:04:27.767 Type: SSH_FXP_LSTAT, Size: 23, Number: 1031
< 2019-01-15 19:04:27.782 Type: SSH_FXP_STATUS, Size: 33, Number: 1031
< 2019-01-15 19:04:27.782 Status code: 2
. 2019-01-15 19:04:27.782 Checking existence of partially transferred file.
> 2019-01-15 19:04:27.782 Type: SSH_FXP_LSTAT, Size: 32, Number: 1287
< 2019-01-15 19:04:27.796 Type: SSH_FXP_STATUS, Size: 33, Number: 1287
< 2019-01-15 19:04:27.796 Status code: 2
. 2019-01-15 19:04:27.797 Opening remote file.
> 2019-01-15 19:04:27.797 Type: SSH_FXP_OPEN, Size: 48, Number: 1539
< 2019-01-15 19:04:27.814 Type: SSH_FXP_HANDLE, Size: 10, Number: 1539
> 2019-01-15 19:04:27.814 Type: SSH_FXP_WRITE, Size: 32790, Number: 2054
. 2019-01-15 19:04:27.829 8 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2019-01-15 19:04:27.829 Type: SSH_FXP_CLOSE, Size: 10, Number: 4356
< 2019-01-15 19:04:27.859 Type: SSH_FXP_STATUS, Size: 21, Number: 2054
< 2019-01-15 19:04:27.859 Status code: 0
< 2019-01-15 19:04:27.873 Type: SSH_FXP_STATUS, Size: 21, Number: 2310
< 2019-01-15 19:04:27.873 Status code: 0
< 2019-01-15 19:04:27.878 Type: SSH_FXP_STATUS, Size: 21, Number: 2566
< 2019-01-15 19:04:27.878 Status code: 0
< 2019-01-15 19:04:27.887 Type: SSH_FXP_STATUS, Size: 21, Number: 2822
< 2019-01-15 19:04:27.887 Status code: 0
< 2019-01-15 19:04:27.892 Type: SSH_FXP_STATUS, Size: 21, Number: 3078
< 2019-01-15 19:04:27.892 Status code: 0
< 2019-01-15 19:04:27.898 Type: SSH_FXP_STATUS, Size: 21, Number: 3334
< 2019-01-15 19:04:27.898 Status code: 0
< 2019-01-15 19:04:27.904 Type: SSH_FXP_STATUS, Size: 21, Number: 3590
< 2019-01-15 19:04:27.904 Status code: 0
< 2019-01-15 19:04:27.910 Type: SSH_FXP_STATUS, Size: 21, Number: 3846
< 2019-01-15 19:04:27.910 Status code: 0
< 2019-01-15 19:04:28.337 Type: SSH_FXP_STATUS, Size: 21, Number: 4102
< 2019-01-15 19:04:28.337 Status code: 0
< 2019-01-15 19:04:28.338 Type: SSH_FXP_STATUS, Size: 21, Number: 4356
< 2019-01-15 19:04:28.338 Status code: 0
> 2019-01-15 19:04:28.338 Type: SSH_FXP_RENAME, Size: 50, Number: 4626
< 2019-01-15 19:04:28.358 Type: SSH_FXP_STATUS, Size: 21, Number: 4626
< 2019-01-15 19:04:28.358 Status code: 0
. 2019-01-15 19:04:28.358 Preserving timestamp [2019-01-14T08:43:45.000Z]
> 2019-01-15 19:04:28.358 Type: SSH_FXP_SETSTAT, Size: 35, Number: 1801
< 2019-01-15 19:04:28.373 Type: SSH_FXP_STATUS, Size: 21, Number: 1801
< 2019-01-15 19:04:28.373 Status code: 0
. 2019-01-15 19:04:28.373 Transfer done: 'testSFTP1.xml' => '/testSFTP1.xml' [290203]
. 2019-01-15 19:04:28.373 File: 'testSFTP2.xml' [2019-01-14T08:43:45.555Z] [290203]
. 2019-01-15 19:04:28.373 Copying "testSFTP2.xml" to remote directory started.
. 2019-01-15 19:04:28.373 Binary transfer mode selected.
. 2019-01-15 19:04:28.373 Checking existence of file.
> 2019-01-15 19:04:28.373 Type: SSH_FXP_LSTAT, Size: 23, Number: 4871
< 2019-01-15 19:04:28.386 Type: SSH_FXP_STATUS, Size: 33, Number: 4871
< 2019-01-15 19:04:28.387 Status code: 2
. 2019-01-15 19:04:28.387 Checking existence of partially transferred file.
> 2019-01-15 19:04:28.387 Type: SSH_FXP_LSTAT, Size: 32, Number: 5127
< 2019-01-15 19:04:28.400 Type: SSH_FXP_STATUS, Size: 33, Number: 5127
< 2019-01-15 19:04:28.400 Status code: 2
. 2019-01-15 19:04:28.400 Opening remote file.
> 2019-01-15 19:04:28.400 Type: SSH_FXP_OPEN, Size: 48, Number: 5379
< 2019-01-15 19:04:28.419 Type: SSH_FXP_HANDLE, Size: 10, Number: 5379
> 2019-01-15 19:04:28.419 Type: SSH_FXP_WRITE, Size: 35836, Number: 5894
. 2019-01-15 19:04:28.442 9 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2019-01-15 19:04:28.442 Type: SSH_FXP_CLOSE, Size: 10, Number: 8196
< 2019-01-15 19:04:28.448 Type: SSH_FXP_STATUS, Size: 21, Number: 6150
< 2019-01-15 19:04:28.448 Status code: 0
< 2019-01-15 19:04:28.455 Type: SSH_FXP_STATUS, Size: 21, Number: 6406
< 2019-01-15 19:04:28.455 Status code: 0
< 2019-01-15 19:04:28.461 Type: SSH_FXP_STATUS, Size: 21, Number: 6662
< 2019-01-15 19:04:28.461 Status code: 0
< 2019-01-15 19:04:28.467 Type: SSH_FXP_STATUS, Size: 21, Number: 6918
< 2019-01-15 19:04:28.467 Status code: 0
< 2019-01-15 19:04:28.474 Type: SSH_FXP_STATUS, Size: 21, Number: 7174
< 2019-01-15 19:04:28.474 Status code: 0
< 2019-01-15 19:04:28.480 Type: SSH_FXP_STATUS, Size: 21, Number: 7430
< 2019-01-15 19:04:28.480 Status code: 0
< 2019-01-15 19:04:28.952 Type: SSH_FXP_STATUS, Size: 21, Number: 7686
< 2019-01-15 19:04:28.952 Status code: 0
< 2019-01-15 19:04:28.952 Type: SSH_FXP_STATUS, Size: 21, Number: 7942
< 2019-01-15 19:04:28.953 Status code: 0
< 2019-01-15 19:04:28.953 Type: SSH_FXP_STATUS, Size: 21, Number: 8196
> 2019-01-15 19:04:28.953 Type: SSH_FXP_RENAME, Size: 50, Number: 8466
< 2019-01-15 19:04:28.971 Type: SSH_FXP_STATUS, Size: 21, Number: 8466
< 2019-01-15 19:04:28.971 Status code: 0
. 2019-01-15 19:04:28.971 Preserving timestamp [2019-01-14T08:43:45.000Z]
> 2019-01-15 19:04:28.971 Type: SSH_FXP_SETSTAT, Size: 35, Number: 5641
< 2019-01-15 19:04:28.985 Type: SSH_FXP_STATUS, Size: 21, Number: 5641
< 2019-01-15 19:04:28.985 Status code: 0
. 2019-01-15 19:04:28.985 Transfer done: 'testSFTP2.xml' => '/testSFTP2.xml' [290203]
. 2019-01-15 19:04:28.985 Copying finished: Transferred: 580,406, Elapsed: 0:00:01, CPS: 467,666/s
> 2019-01-15 19:04:28.986 Script: exit
. 2019-01-15 19:04:28.986 Script: Exit code: 0
. 2019-01-15 19:04:28.986 Closing connection.
. 2019-01-15 19:04:28.986 Sending special code: 12
. 2019-01-15 19:04:28.986 Sent EOF message
Re: winscp script returning error level 1 after successful transfer
I find it quite unlikely that the log file is from your command, as it's just wrong and would never execute the script file.
The /script="C:\temp\winscp.txt -resumesupport" should try to execute file C:\temp\winscp.txt -resumesupport, which for sure does not exits. And that would explain the exit code 1.
The -resumesupport switch should go to the put command in the script (and it needs a value anyway):
https://winscp.net/eng/docs/scriptcommand_put#resumesupport
Thanks for the feedback. I changed the put statement and it worked.
put *.xml -resumesupport=off  -nopermissions
