my script doesn't append the log files anymore, instead it overrides them
leonardo07746
cuba
Need help with this, I have winscp 5.7.5 and my script doesn't append the logs anymore, in the Winscp settings at tools/reference/logging/ the enable session box is checked and in the Log to file box i entered:
"C:\LOGS JOURNALS\logsdelScript_!Y_!M_!D.log" Below the append option is checked
the script goes like this:
@echo off
winSCP.com /command ^
   "option batch abort" ^
   "open ftp://user:password@192.168.x.xx/" ^
   "synchronize local C:\Sabcc\JOURNAL /Journals/TRuSVAL -filemask=*>"2016-09-20 "
   "close" ^
   "quit" ^
   /log= "C:\LOGS_JOURNALS\logsfromScript_!Y_!M_!D_!T.log" /loglevel=1
 "quit"
By reading the put and append command documentation the line of the logs should goes like this but still doesn't append them.
put -append /log= "C:\LOGS_JOURNALS\logsfromScript_!Y_!M_!D_!T.log" /loglevel=1
Reply with quote E-mail
Re: my script doesn't append the log files anymore, instead it overrides them
But you override that in your script with:
/log="C:\LOGS_JOURNALS\logsfromScript_!Y_!M_!D_!T.log"
The !T makes the file name different every second. So there's never a log file to append to with that name.
