Unknown command 'ssh-rsa'
emalcolmb
Context: I have CSV files I'm outputting through BCP in SQL Server. I'm trying to securely transfer to a remote SFTP folder using WinSCP.
Details: When I execute the batch file below through powershell I raise an error 'Unknown command 'ssh-rsa' with the log file showing an exit code = 1 which is failure.
Here is what my synchronization file looks like...
option batch abort
open sftp://username:password@sftp.redacted.com -hostkey="ssh-rsa 2048 redacted=ssh-rsa 2048 redacted"
synchronize remote D:\redactedDaily_Reports\redacted_Catalog_New_Item /upload/redacted_catalog
and & my batch file...
winscp.com /script=SyncTo_redacted_catalog.txt /log=D:\redacted_Daily_Reports\winscp_log_catalog.txt
pause
Here is a snippet of my log file...
. 2019-03-06 23:39:28.379 Access granted
. 2019-03-06 23:39:28.379 Opening session as main channel
. 2019-03-06 23:39:28.447 Opened main channel
. 2019-03-06 23:39:28.583 Started a shell/command
. 2019-03-06 23:39:28.583 --------------------------------------------------------------------------
. 2019-03-06 23:39:28.584 Using SFTP protocol.
. 2019-03-06 23:39:28.584 Doing startup conversation with host.
> 2019-03-06 23:39:28.584 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2019-03-06 23:39:28.769 Type: SSH_FXP_VERSION, Size: 95, Number: -1
. 2019-03-06 23:39:28.769 SFTP version 3 negotiated.
. 2019-03-06 23:39:28.769 Unknown server extension posix-rename@openssh.com="1"
. 2019-03-06 23:39:28.769 Supports statvfs@openssh.com extension version "2"
. 2019-03-06 23:39:28.769 Unknown server extension fstatvfs@openssh.com="2"
. 2019-03-06 23:39:28.769 We believe the server has signed timestamps bug
. 2019-03-06 23:39:28.769 We will use UTF-8 strings until server sends an invalid UTF-8 string as with SFTP version 3 and older UTF-8 strings are not mandatory
. 2019-03-06 23:39:28.769 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2019-03-06 23:39:28.769 Getting current directory name.
. 2019-03-06 23:39:28.769 Getting real path for '.'
> 2019-03-06 23:39:28.769 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2019-03-06 23:39:28.837 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2019-03-06 23:39:28.837 Real path is '/'
. 2019-03-06 23:39:28.837 Startup conversation with host finished.
< 2019-03-06 23:39:28.837 Script: Active session: [1] redacted@sftp.redacted.com
> 2019-03-06 23:39:28.838 Script: ssh-rsa 2048 redacted
< 2019-03-06 23:39:28.838 Script: Unknown command 'ssh-rsa'.
. 2019-03-06 23:39:28.838 Script: Failed
. 2019-03-06 23:39:28.838 Script: Exit code: 1
. 2019-03-06 23:39:28.838 Closing connection.
. 2019-03-06 23:39:28.838 Sending special code: 12
. 2019-03-06 23:39:28.838 Sent EOF message
Questions: Why am I raising this error & how do I fix it? Is this error trying to tell me that I'm using an incorrect key-fingerprint -- If so, why is that the case when a) I obtained this key directly from the server when I connected successfully the first time and b) the log file appears to show the initial connection was successful?
Please help Any tips or recommendations greatly appreciated.
https://stackoverflow.com/questions/55034351/winscp-ssh-error-unknown-command-ssh-rsa
