Is it possible to change default confirmation answer?
Damir
Hello!
I'm using WinSCP.com (Version 5.13.8 (Build 9278) (OS 6.1.7601 Service Pack 1 - Windows 7 Professional) to download files via FTP from a remote computer to a local Windows IIS ftp server. Our network is quite unstable and I have to reconnect often.
Here's the contents of Batch file that I'm using:
"C:\Program Files\WinSCP\WinSCP.com" ^
  /log="D:\WinSCP.log" /ini=nul ^
  /command ^
    "open ftp://anonymous:anonymous%%40example.com@10.2.2.21/" ^
    "cd "Sterlitamak" " ^
    "lcd "D:\Beholder\Audio" " ^
    "synchronize remote -transfer=binary -filemask=*>1M>=%%TIMESTAMP-1D#yyyy-mm-dd%%<%%TIMESTAMP#yyyy-mm-dd%% -resumesupport=on" ^
    "exit"
and in WinSCP.com's window I get something like this:
Connecting to 10.2.2.21 ...
Connected
Starting the session...
Session started.
TV-591,25( |      259799 KB |    0,0 KB/s | binary |  12%
Lost connection.
Timeout detected. (data connection)
(A)bort, (R)econnect (0 s): Reconnect
Connected
Session started.
TV-591,25( |            0 B |    0,0 KB/s | binary |   0%
Error transferring file 'TV-591,25(190302-2200).wmv'.
The process cannot access the file because it is being used by another process.
I would like my script to choose "Retry" after a few seconds instead of "Abort"
Thanks in advance, would be great to get this problem solved!
Kind regards
