How to bring background transfers to the foreground?
NewUser
This should be a simple task but for some reason I cannot find any option that allows me to bring the background transfer to the foreground.
Really?
You mean you can't see a use case where you would want to check on your background transfers. Maybe see how far they have come, maybe to cancel the operation altogether or maybe figure out if you can close the program and restart your pc already.
It shouldn't have been implemented without an undo function built in, that's just basic HCI.
@radekzc: Thanks for your report.
Jeroen45
Hi there!
Sorry for bumping this topic, but this is the only reference to this problem I could find, and I'm still experiencing this problem with WinSCP 5.17.10. Is any fix known yet, apart from downgrading to older versions?
Thanks in advance for any update on this.
I never got any feedback from anyone regarding this (seemingly very rare) problem.
Can you post a session log file showing the problem (using the latest version of WinSCP)?
Jeroen45
Thanks for your reply, I've attached the (modified to hide identifying information) log file. I also think I might have found more specific steps to reproduce the problem. I noticed that the problem doesn't occur when dragging files from within the left local directory window within the program to the right remote directory window to upload them, and then clicking the proceed in background button. The problem only occurs when the same steps are followed, but the files are dragged to the remote directory from a Windows Explorer window outside the program. Hopefully this information helps, thanks a lot for taking a look at this problem.
Thanks for the details. Though I still cannot reproduce the problem.
Transfer halts when Background transfer selected
Okay, I'll start again. Free program and I always appreciate free. Still I saw this problem from last year. It's near August 2021 and seems this problem is still in WinSCP. But that background transfers ain't workin' is the least of my issues.
I'm running a fairly ordinary Windows 10 on an HP laptop. I only installed WinSCP this morning and it imported my server connection details for me. Brilliant. So I was off to a good start.
So onward I go. Well into a big single file transfer I selected background transfer and wham, transfer ceased. Shit!
I managed to get it to restart where it left off thankfully, but all incremental numbers were gone so it was adding to the existing file but telling me new download numbers as if it was first run.
There is no updating of file download size in the (classic) window and no access to the main interface anytime.
This is a trap for users in my circumstance; big file, invested gigabytes downloading with lots to go, cannot select ANY menu items as the small transfer window has complete precedence.
If I select background transfer I assumed I could then get to the menus and setting but no can do. The main issue FOR ME is, no menu item is accessible while it's transferring file/s, no updating of file size in the actual folders and I gotta ask, why have them there if they never update? Weird.
Thanks for reading guys and keep safe eh.
phil
Re: Transfer halts when Bckground transfer selected
What version of WinSCP are you using? Can you reproduce this problem?
What prevents you from using the menus, while transferring the files on the background?
