Exit status 127
neel14
India
Exit status 127
Hi everyone,
I am using WinSCP to connect to an HPC cluster through SFTP. I had been using WinSCP for for half a year without any issues untill yesterday, suddenly it broke. I started getting the error "Server sent command exit status 127".
The funny part is that I am able to connect with colleagus acoounts on the HPC without any issue. Problem only with my account. IT guys are not helping much.
Any help would be helpful. Thanks!
Re: Exit status 127
Can you connect with any other SFTP client?
