Timestamp not copied correctly.
ljhaywood
England
I've encountered a recurring issue whenever I amend a file on the server and then immediately afterwards copy it to my PC - the date/time of the copy has the original value rather than today's date.
The file contents are correct and copying the a file again gives the expected timestamp, but I've never had this issue before and it was fortunate that I noticed it before continuing. Might this be due to any recent changes to WinSCP?
Re: Timestamp not copied correctly.
Could it be that the upload actually did not finish yet, when your started the download?
Can you reproduce the problem? If you can, please attach a full session log file showing the problem (using the latest version of WinSCP).
