GetFiles interrupted corrupt remote file
Err94
Hi.
I am working on a c# application with WinSCP library.
To download file (using WebDAV) i am using getfiles. But if i try to force connection lost during transfer remote file becomes corrupted.
There is some trick to avoid this situation?
Re: GetFiles interrupted corrupt remote file
Do you mean that, if you abort the connection during a download, the source files on the server get corrupted?
If you want us to investigate closer, please attach a full session log file showing the problem (using the latest version of WinSCP).
Though I'm 99% sure, that this has nothing to do with WinSCP. It must be server-side problem.
