Moving files on a remote server from one directory to another is failing with Rename Failed
jamesvdale
Atlanta
Using Winscp 5.15.2 on Windows 10.
When I use the GUI and drag a file to a subdirectory I get "Error moving file <> to <path?/filename.
I am able to see other files in the subdirectory.
Here is the log snippet:
Using FTP protocol
. 2019-06-17 15:22:01.499 Moving file "ADMER_20190614_033320-athena.hl7" to "/export/payroll/ADMER_20190614_033320-athena.hl7".
> 2019-06-17 15:22:01.500 RNFR /export/payroll/athena/ADMER_20190614_033320-athena.hl7
< 2019-06-17 15:22:01.511 450 Rename Failed
. 2019-06-17 15:22:01.511 Asking user:
. 2019-06-17 15:22:01.511 Error moving file 'ADMER_20190614_033320-athena.hl7' to '/export/payroll/ADMER_20190614_033320-athena.hl7'. ("Rename Failed")
Reply with quote E-mail
Re: Moving files on a remote server from one directory to another is failing with Rename Failed
What FTP server is that? Please attach a full session log file showing the problem.
Log is attached.
Server is WS-FTP 7.5, on Windows Server Enterprise 2008SP2.
I have no problem copying the test.txt file from my local directory to the ftp server. I can also copy files to the destination (/archive) folder using Winscp. I just cannot move files between remote folders.
Thanks, James
Using FTP protocol
Can you rename/move a file using any other FTP client?
