Editing symlinks
heyesr
Editing symlinks
When I have a symlink to a text file and I edit the symlink and save it - the link is overwritten with a new file - ie the link is not preserved.
Is there some configuration that I must do to make winscp preserve the link? This happens even with the WinSCP internal editor.
Richard
Re: Editing symlinks
What protocol are you using? Please attach a full session log file showing the problem (using the latest version of WinSCP).
heyesr
That was it thank you - the protocol was set to SFTP instead of SCP. So I changed to SCPP and it works fine. Thank you.
Richard
OK, but can you post a log file for SFTP anyway?
heyesr
Log file
I've found that it doesn't seem to be a protocol thing - I have two connections setup - one with a private key and one with a password - and it's only the private key connection that doesn't work properly.
Log file is attached.
  • __winsp-log.log (198.15 KB, Private file)
Description: WinSCP log file
heyesr
That appears to be it
That appears to be it - I unchecked that box and it appears to be editing files and symlinks as expected.
Thanks.
Richard
