WinSCP SFTP download gets error Invalid parameter each time after 4126KB data is downloaded
zousijiu
Hello, I'm trying to use WinSCP to download file from a SFTP, however, I got the following error message every time after 4126KB data downloaded. If the file is less than 4126KB, there is no problem.
One of the parameters was out of range, or the parameters specified cannot be used together.
Error code: 23
Error message from server: Invalid parameter
But there is no problem with fillezilla.
I tried to change the settings like Timeout, protocol, etc, but always the same error.
Is there any configuration can cause this? Client side or Server side?
Any help would be greatly appreciated.
Re: WinSCP SFTP download gets error Invalid parameter each time after 4126KB data is downloaded
Please attach a full session log file showing the problem (using the latest version of WinSCP). Set logging level to "Debug 1".
