Network error: Connection timed out
SDUJS
USA
Good Afternoon,
I'm running into an issue where my scheduled task works most of the time. When it fails, even with verbose logging I get Network error: Connection timed out
The question I have is I have the timeout set to 100 seconds but my log shows it failing after 23 seconds. Is there another timeout I'm missing for connections?
My script
open sftp://user:password@sftp.website.com/ -hostkey="ssh-rsa 4096 (key)" -timeout=100 -passive=on
From the log
2019-07-23 02:01:42.214 Connecting to XX.XXX.XXX.XX port 22
2019-07-23 02:02:03.227 Failed to connect to XX.XXX.XXX.XX: Network error: Connection timed out
Chris
Re: Network error: Connection timed out
Though, in genera, the operating system can choose to timeout sooner. How long does the connection take, when it works?
You can also consider simply retrying the script:
https://winscp.net/eng/docs/script_retry
