Looking for option to ignore failing delete operations during a synchronize command
macfarmw
Houston
There are some files on the remote server with special characters in them and when WinSCP tries to delete one of them during
synchronize
it fails. It attempts to prompt for Abort, Retry, or Skip. Since this is in a script and no can answer it defaults to Abort and the process stops.
It will be very helpful if I can configure the
synchronize
command so that it can default to skip in these cases. I could not find the answer in the help although I will keep searching.
Is there such an option on the
synchronize
command?
Matthew
