Cannot logon using non-default "SFTP Server" option
MrCalvin
DK
I'm only able to connect with SFTP when using "SFTP Option=Default".
I've tried "SFTP Option=/bin/sftp" (I only have "/bin/sftp" on the server), but I get error 1.
I logon as root user.
Been looking for answers in the WinSCP log-file (Debug 2) but without luck.
Server is Debian Buster.
Re: Cannot logon using non-default "SFTP Server" option
I'm not sure what you mean by "SFTP Option". Do you mean "SFTP server" session setting?
https://winscp.net/eng/docs/ui_login_sftp
There you need to specify an SFTP server. sftp is a client.
What are you trying to achieve?
MrCalvin
DK
Yes, the "SFTP server" value (see screen-dump)
The documentation says "Use SFTP server to specify path to SFTP server binary".
I assume it is the binary of SFTP-server/daemon on the remote server, right?
How is this relevant for the client (WinSCP)? The client just connect on port 22 using some protocol and cannot instruct the remote-server on which binary/server/daemon to use (or can it, does it first connect with SSH and the tell the remote-server to switch to SFTP, and thereby which binary to start?)
Description: screen-dump
Yes, SFTP client can instruct the SSH server what binary to execute.
Again, what are you trying to achieve?
