Copying files to remote side failed. No such file or directory
knert
Europe
After getting this error ALL the time I thought it would be easy to search for a solution.
Now 6 hours, and not a single solution my Winscp with hundreds of sites seems totally messed up. My configurations seems totally wrong and i STILL get the same error.
I don't want errors, I simply want to upload thousands of files simultaneously
I tested the same dir on another ftp client: not a single problem. So it must be some configurationthing.
Hope for a solution.
Kind regards,
Knert
Re: Copying files to remote side failed. No such file or directory
A log file from the "another ftp client" might be useful too.
knertje
RE
Here it is.
Again, loads of errors. I guess it has to do with settings. But then again, there are hundreds of settings which, for me, it's impossible to adjust like they should be.
Some of the errors I get. It drives me crazy and costs me LOTS of time and money. :(
Session unkeep
System Error. Code: 32.
Again, it's a bunch of random errors. The only thing I want is no errors and a proper working Winscp.
Re: RE
There's no error in the log you have posted. Please post a log file of the operation that failed. And can you also post a log from the "another ftp client"?
knert
Europe
Another error:
Disconnected from server
Connection failed.
Unfortunately I uninstalled the other FTP client but the client was Cyberduck.
The strange things is when I shut down the client via Taskmanager and restart it, it works... for the time being.
Here a new logfile that I created on the above error notification.
By "client", do you mean WinSCP? – So WinSCP cannot connect, you kill it, start it again and then it can connect again? Do you have to kill it? Won't mere close suffice?
knert
Yes. I mean the Winscp program.
Afer that it works again, until I have the program up and running for some time. The problems are only there when upload.
Quarkitect
Scotland
I also have been having the same error message while transferring thousands of files. Seems like the same issue
I checked different versions and the same error occurs on versions above 5.15. Version 5.13.9 seems to have no problems which im currently using.
For me, opening WinSCP, connecting to one site, and transferring those files will produce errors.
It seems to occur randomly on some files, while most other files transfer fine in the same batch. Using FTP and FTPS both produce the same error. Retrying when an error occurs sometimes transfers the file, other times retrying a dozen times continues to produce the same error.
I dont have any log files unfortunately, but hope that this info helps
knert wrote:
Approx 10-15 minutes.
No, it happens even when I have one connection open.
So you disconnect your only open connection and when you try to open it again, it does not connect anymore?
Please attach the logs.
knert
Europe
I tried an older version 5.13.9. but again, same error(s) when uploading several dirs at the same time:
/httpdocs/test/xxxxx/xxxxx: No such file or directory
So it seems Version-independent and looks like some universal setting. But since there are hundreds of settings may be there is an option to reset all settings to standard?
RE:
Can I do that in private?
There is lots of private information on it.
Last error: Couldn't login any more. Closed down the Winscp, restarted it, and it worked again.
