Download files and move after download on to the remote server
Uli
Germany
Hi
I want to download data and then move it on the remote server. I want to keep the folder structure. And exclude the backupfolder for downloading
I used this example:
Moving local files to different location after successful upload
This is my code:
$localpath = "C:\Temp\Download\"
$remotepath = '//*'
$remotepathbackup = '/backup/'
    try
        # Connect
        # Download files, collect results
        $transferResult = $session.GetFiles($remotepath, $localpath)
        # Iterate over every transfer
        foreach ($transfer in $transferResult.Transfers)
            # Success or error?
            if ($transfer.Error -eq $Null)
                Write-Host "Download of $($transfer.FileName) succeeded, moving to backup"
                # Upload succeeded, move source file to backup
                $session.MoveFile(($transfer.FileName), $remotepathbackup)
            else
                Write-Host "Upload of $($transfer.FileName) failed: $($transfer.Error.Message)"
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
Uli
Germany
Martin, thanks for the quick answer!
How I can skip the folder backup was one of my questions.
After downloading the data, how can I move the data from the root directory to the backup directory while keeping the folder structure? For example, there are two folders, in the root directory and there are several files in them. These 2 folders should be moved to the backup directory after downloading, including all files in them. The files should remain in the folders.
That's a very different operation than your current code does.
It is also hard to implement in an atomic way. What if some process adds the file to the folders between the moments when you (1) download and (2) move the folders?
Is that a risk you can take? Or avoid (e.g. by running your PowerShell script at a time, when no files can be added)?
Are there any files in the root folder?
Uli
Germany
I know exactly when dates are added (at night).
After this time I download the data and check the completeness. I could then start a second process that moves the data from the root directory to the backup directory. Do you have an example script for this?
There are only folders in the root directory. No files.
$folders = $session.EnumerateRemoteFiles(
    $remotepath, $Null, [WinSCP.EnumerationOptions]::MatchDirectories)
foreach ($folder in $folders)
    if ($folder.Name -ne "backup")
        $session.MoveFile(
            $folder.FullName,
            [WinSCP.RemotePath]::Combine($backuppath, $folder.Name))
