The server rejected SFTP connection, but it listens for FTP connections.
Eric8isles
Malaysia
I started having this error after I changed my server SSH default port 22.
I already changed the port number in the software WinSCP but still getting this error.
Does anyone have a solution for this?
Reply with quote E-mail
Eric8isles
Malaysia
Re: The server rejected SFTP connection, but it listens for FTP connections.
Can you connect with any other SFTP/SSH client?
I can log in by using FileZilla.
Eric8isles
Malaysia
Let me correct myself. I used WinSCP to do backup for my server. And I used an automation script to copy backup file from my server to HDD. I can log into the server by WinSCP but the backup automation is rejected.
So please post logs both from the script and GUI.
Though I would guess that the problem is due to a host key verification.
See https://winscp.net/eng/docs/faq_scheduler
Eric8isles
Malaysia
Script used to sync local script:
option batch abort
open %1% -hostkey="%2%"
synchronize local %3% "%4%"
script used to copy backup from server
rem vps10
winscp.com /ini=nul /script=SyncToLocalScript.txt /parameter sftp://xxxLOGINIDxxx:xxxPASSWORDxxx@xxxIPADDRESSxxx "ssh-ed25519 255 xxxSHA-256IDxxx="xxxSOURCExxx" xxxDESTINATIONxxx
Eric8isles wrote:
Anyone? Please help me.
If you want our help, then you need to provide us the information we ask for.
Once again: Please post logs both from the script and GUI.
Eric8isles
Malaysia
I posted it. That information still not enough?
