Unable to log in
Galib
Brussels
Unable to log in
Hi all,
I'm unable to log in to the WinSCP client after having upgraded one of our coprorate servers. Although I've created a backup of the config file, when I import it I'm still unable to log in, and keep getting the 'Access denied' message with a password prompt.
Could you please assist.
Best regards,
George
Re: Unable to log in
Did you upgrade the server you are connecting to? Or the machine you are connecting from?
Galib
Brussels
Hi, Martin.
Thank you for you reply. I managed to generate a one-time password via the CLI, and I can successfully log in, however I need to do it for a every new session, and besides I don't have the right permissions to create a new folder or file.
And if I set a master password what username shall I use to log in?
mennettip
United States
Hi Galib. I've had a similar problem when updating the WinSCP. I use C# to upload and download files, and I've found I've had to recompile the C# programs with the new DLLs referenced in the project.
Pete
Reply with quote E-mail
OK, then it does not look like WinSCP question. Please talk to your administrator.
Do you mean WinSCP master password? That has nothing to do with your problem.
I believe that Gelib/George uses WinSCP GUI.
Galib
Brussels
Hi Martin,
Thank you for your response. I used a workaround by creating a new folder in the home directory instead of root, and setting required permissions on that particular folder.
I really appreciate your help.
Take care!
George
