Compare webdav client RFC4437 Redirecting vs. Other Servers?
manhdung0899
hà nội
my name is Silvio, I'm working on a research istitute in Italy.
For our experiment we use webdav endpoint that aggregate multiple wedbav storage in a single namespace. Would be nice use winscp to access to those data, however I see that winscp does not follow redirection, maybe because the system use to redirect the client to endpoints which are different from the starting one.
Would be possible change this bheaviour, allowing the client to follow redirection even to different endpoint as browser does? Maybe the user can select it as an option, if this apporach is conisdered bad from a security point of view.
This possibility should be allowed by RFC4437.
Thank you for your attention and congratulation for your nice client.
Best Regards,
Silvio
Re: Compare webdav client RFC4437 Redirecting vs. Other Servers?
