Cannot unset setgid on folder
MrCalvin
DK
Cannot unset the setgid bit on folders, at least not on Debian.
It seems on Debian using e.g. "chmod 0770" doesn't unset the bit, you have to use e.g. "chmod 00770" (see this thread unix.stackexchange.com/..)
I don't know if that's the problem but it's likely I guess.
Version. 5.17.1 (Build 10240)
Re: Cannot unset setgid on folder
Thanks for your report. What protocol are you using?
