Folder Structure problem with backspace or ".." button to go parent folder
srtc91
Ankara/Turkey
Hello
At the first photo, you can see my Android phone's SD Card with FTP Server feature by MixPlorer. It has a basic folder structure.
Then second photo, i enter a folder then i try to enter parent folder with "backspace" button or ".." which the button at the top of the folder lister, then i enter the other folder then again i go to parent folder... As you can see there's diffrent bug that i can experience at least one year. Will that be solved?
Have a nice day.
I'm using the latest version as always (almost one year and it's a time that i've meet with Winscp)
I'm using Windows 10's latest version , i mean updates are not closed.
I'm using the FTP server, not SFTP etc.
Re: Folder Structure problem with backspace or ".." button to go parent folder
Also please reset cache before the test (Commands > Clear Caches).
srtc91
Ankara/Turkey
Hello, i'm adding the log file. Thanks for your interest.
BTW, i want to ask that is it cause to disrupt files when the address bar is filled as : "/Folder A/../Folder B/Folder C"
Folder structure is:
/Folder A/*.*
/Folder B/Folder C, Folder D, *.*
Did you reset the cache?
It does not look like you did:
. 2020-04-03 01:53:51.582 Cached directory change via ".." to "/#PCDekiler/..".
I do not understand the question.
Yes i did. It was second and third attempt.
OK, I see.
Well, that's how your server behaves. After WinSCP does CWD .., it reports the current working directory as /#Gecici/.., which it should report /.
> 2020-04-03 01:54:42.582 CWD ..
< 2020-04-03 01:54:42.786 250 CWD Done
. 2020-04-03 01:54:42.786 Getting current directory name.
> 2020-04-03 01:54:42.787 PWD
< 2020-04-03 01:54:42.794 257 PWD "/#Gecici/.."
