Not all remote files are listed in a WebDAV connection
dfousek
Greece
Hi!
I have an issue with WebDAV remote folders not showing correctly with WinSCP, while showing correctly with Win10's file explorer. In Win10 I have already modified the necessary registry entry to increase the preset limit above 50MB.
Any ideas?
Dimitri
Re: Not all remote files are listed in a WebDAV connection
Can you see the files in any other real WebDAV client? What WebDAV server is that? I believe that Windows File Explorer use some tricks when connected to Microsoft servers.
dfousek
Greece
Hi Martin,
It is a National Instruments DAQ device (CompactRIO series, running NI-Linux with opkg packages).
Win10's file explorer lists correctly files/folders, but has other issues e.g.: with cache, with dir contents refreshing, etc.
WinSCP was the 1st 'real' WebDAV to try....
Dimitri
So what does it exactly mean "not showing correctly"?
dfousek
Greece
Martin, I am attaching you the logs and screen captures of two sessions (sftp and webdav).
Dimitri
  • 2xLogs and ScreenCaptures.7z (136.58 KB, Private file)
Those are all files and folders with spaces in their name.
It's because the server encodes their URLs incorrectly.
A correct URL in the server response would be like:
<D:href>/files/u/This%20is%20the%20miniCORSAIR%20USB.txt</D:href>
While your server responds:
<D:href>/files/u/This is the miniCORSAIR USB.txt</D:href>
dfousek
Greece
Hi Martin,
By enabling the "Tolerate non-encoded ..." option, I can see files, I wasn't able to do with last version.
However, when I tried to drag'n'drop a file with greek characters and spaces, the uploaded file name ended up with ????? (and the spaces in the correct places). But, I am not sure, if this is WinSCP issue or a National Instrument's problematic WebDAV server...
Bye,
Dimitri
gm
Quarantine
Bug 1876
I am developing an application to run on National Instruments hardware running their WebDAV server. I've reviewed the discussions regarding bug 1876 and it certainly appears that this is same issue. I am not able to see files that contain a space character when contacting the remote target from WinSCP. Could you provide me with access to the 5.18 beta release? I'm hoping this will help me convince their tech support staff that this is an issue that needs fixing on their end. I've attached a log for reference in case it helps. Thanks in advance.
  • pxi-http.log (34.51 KB, Private file)
Re: Bug 1876
iayestaran
could I get the developement version too? I have the same problem and I see you fixed it in version 5.18, which is still not available.
Sent.
iayestaran wrote:
I did not receive any email. Could you please re-send me the 5.18 version?
Thanks.
I've sent it again. Also, 5.18 beta will most probably be released the next week anyway.
