Remote side unexpectedly closed network connection
jhoag
jhoag avatar
Newark, NY
I'm having the same type of issue as was described in this post, right down to the version of WinSCP that I started encountering the error with which persists today into the latest version: https://winscp.net/forum/viewtopic.php?t=29081
I unfortunately, don't have the luxury of downgrading WinSCP however to address the issue, and am wondering if a solution was found, which didn't get added to the post above, because I see no updates to the article since 2020-03-27.
I've attached a WinSCP Log File that I generated (set to private), which includes the error described in the subject of this post. In my environment, we are using the latest version of WinSCP (v5.17.3 build 10325) to connect to the latest version of WingFTP Server (6.2.9) => https://www.wftpserver.com
For your awareness, I've also opened a "case" with the vendor for WingFTP Server to report this issue, which you may be able to reference here for additional information: https://bbs.wftpserver.com/viewtopic.php?t=3601
Let me know what other information you might benefit from having!
  • WinSCP.log (17.2 KB, Private file)
Description: This is a fresh log file from the connection from WinSCP to WingFTP Server
Re: Remote side unexpectedly closed network connection
jhoag
jhoag avatar
Re: "Remote side unexpectedly closed network connection"
Thanks for the response. The link I received was to download what I believe is a "debug" version of WingFTP...and not WinSCP. Is that what you intended to send me?
jhoag
jhoag avatar
Newark, NY
New Message with Development version of WinSCP
I'm now getting a different "message" than before with the development version of WinSCP that you supplied:
. 2020-04-20 17:34:45.607 Copying finished: Transferred: 257,814, Elapsed: 0:00:00, CPS: 7,032,687/s
> 2020-04-20 17:34:45.607 Script: close
. 2020-04-20 17:34:45.607 Closing connection.
. 2020-04-20 17:34:45.607 Sending special code: 1
. 2020-04-20 17:34:45.623 Main session channel closed
. 2020-04-20 17:34:45.623 All channels closed
The "Special Code" still triggers my system to think something is wrong, and that the upload did not proceed as expected. I've attached another private copy of the log file for your review.
What's next?
Jeff H - Data Systems Specialist
New York, USA
  • WinSCPLog_04202020.txt (34.25 KB, Private file)
Description: WinSCP Log File from Today 04/20/2020
