Sync but not delete a certain folder,sync and delete normally the rest..
mariofenech
Usa
Hi
I got a script running moving recordings from 1 raspberry pi to another..
script looks like this:
option batch abort
open sftp://xxx:xxx@xx.xx.xxx.xx/ -hostkey="ssh-xxxxxxxxxxxxxxxxxxxxxxxxx="
synchronize local \\192.168.0.5\hdd\Tv_Shows_Recordings /var/media/usb128/recordings
This is working fine for synchronizing my files but I want to add -delete function to source..that also works fine but problem is I want to exclude a folder and it's content from being deleted but still want it to synchronize so not sure how to create a filemask to exclude this folder from being deleted after sync..I understand that a normal filemask will eventually even exclude the folder from being sync..
Thanks for any help..
Reply with quote E-mail
Re: Sync but not delete a certain folder,sync and delete normally the rest..
Do you mean that, if the local (sub)folder exists, you want to upload new and modified files to the corresponding remote (sub) folder?
But if you delete the local (sub) folder (or some files in it), you do not want the synchronization to delete the corresponding remote (sub) folder (or the files in it)?
Then you can can exclude the (sub) folder from the overall synchronization (which will use -delete). And then run another synchronize command only for that (sub) folder (without -delete).
mariofenech
Usa
The local recordings folder has many subfolders in it..which I wanted to delete after sync..that was working fine..but now I need to exclude 1 of the subfolders from deleting..so if i understand well if I exclude that subfolder with a filemask it is even excluded from syncronisation..I cannot add a filemask just for delete in same script..So conclusion..I have to leave script as is just for sync and create a new one with -delete and filemask that subfolder..or add delete to existing one and filemask that subfolder altogether and create a script with sync just for it..thanks
