SFTP Session shortcut behaves differently between users
JMikolajek
Colorado
I used WinSCP to create an sftp session to a server and saved a shortcut for that session. My account that is a server admin connects to the session in the expected manner. A connection is established with the server using the appropriate account. For the sake of this post, the account name is "User." The account is case sensitive. When I try to connect, all I am prompted to do is enter a password. After entering the password I successfully connect. When I have another person who needs to use the shortcut try, the behavior is different. Instead of prompting for the password, this user is prompted to enter a user name and then prompted to enter a password. Even after entering the correct user name and password the connection fails. This is the contents of the failing connection's dialog box:
Searching for host...
Connecting to host...
Using username "User".
Server refused our key.
It does not appear to be a permissions issue on the shortcut itself. I've tried this from 2 different servers and getting the same results. Please help... I'd really like to get this working for this person..
Jim
Re: SFTP Session shortcut behaves differently between users
Please attach a full session log files for both scenarios (using the latest version of WinSCP).
Though I would guess that the working instance uses a stored site on that machine. While on other machines, you refer to the "same" stored site, that does not exist there.
There's no "Server refused our key" in either log.
Both sessions connect successfully using a key.
Btw, are you aware that there are different servers? transfer-test.is.colostate.edu vs. transfer-prod.is.colostate.edu.
JMikolajek
Colorado
SFTP - correct log file for bad connection
I'm sorry - that was my fault. Here is the log file with the failure to connect. What looks to be happening is a failure in authentication. The username (Ucis) for the target system is case sensitive. When attempting to use the shortcut, the username is being passed all-lower case. Even when trying to manually connect. Weird how that behaves that way for my user but not when I try it.
Jim
Re: SFTP - correct log file for bad connection
The username is Ucis in the working session, but ucis in the non-working session. Usernames are case-sensitive in Linux systems.
JMikolajek
Colorado
Username
Yes, that looks to be the cause. I see no reason why that is different for my user. We are both using the same shortcut. Even when using the WinSCP client. Is there something saved in her profile I can reset? I think when my user initially tried connecting may have entered the username in all lowercase. It feels like WinSCP is using some cached information.
Jim
