error loading file from * nix with the incorrect special symbol in the file name for Windows
zerohalf@...
I'm trying to download files from *nix with powershell script using WinSCPnet.dll:
               HostName = "<srvr_url>"
               UserName = "<user>"
               Password = "<pass>"
               SshHostKeyFingerprint = "ssh-rsa 2048 tw5wuHrOrBUrBIsv3j9HQdJ8stWQzPKI6J881afD5P0="
$fileInfos =
   $session.EnumerateRemoteFiles(
      $RemoteDir, "*$FileMask.xml",
      ([WinSCP.EnumerationOptions]::EnumerateDirectories -bor
         [WinSCP.EnumerationOptions]::AllDirectories))
foreach ($fileInfo in $fileInfos)
   $localFilePath = $fileInfo.Name -replace "[\0\\r\""\*\\a\/\\b\:\t\<\n\>\\v\?\\f\\\|\']+",''
   $localFilePath =
      [WinSCP.RemotePath]::TranslateRemotePathToLocal(
         [WinSCP.RemotePath]::Combine($RemoteDir,$localFilePath), $RemoteDir, $LocalDir)
   Write-Host $localFilePath
   Write-Host "Downloading file $($fileInfo.FullName)..."
   # Download file
   $remoteFilePath = [WinSCP.RemotePath]::EscapeFileMask($fileInfo.FullName)
   $transferResult = $session.GetFiles($remoteFilePath, $localFilePath)
   # Did the download succeeded?
   if (!$transferResult.IsSuccess)
      # Print error (but continue with other files)
      Write-Host (
         "Error downloading file $($fileInfo.FullName): " +
         "$($transferResult.Failures[0].Message)")
and catch error:
get_adm.ps1 : 'WinSCP.TransferEventArgs.Destination':
Exception when calling "Create" with "2" arguments: "The path contains invalid characters."
line: 1 character: 1
+ <script_name>.ps1
+ CategoryInfo : NotSpecified: (:) [Write-Error], WriteErrorException
+ FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,<script_name>.ps1
...and catch same error if $localFilePath declared as in example:
$localFilePath =
                    $fileInfo.FullName, $remotePath, $localPath)
zerohalf@... wrote:
*nix filename like this 1-8190PIR2_PDQ_*all_1-8H41KJ.xml
In Windows, * is not allowed in file name. If you want to download such file, you will have to give it a different name. Normally WinSCP would do it automatically. But as you explicitly specify the target file name to contain * in $localFilePath, you force WinSCP to fail.
zerohalf@...
thnx, but answer not for my question
I've asked what I have to do for avoid error when just downloading file. In case of this error winscp.dll ignores targetfilename
Re: thnx, but answer not for my question
OK, I have probably misunderstood the problem.
Where exactly do you get the exception? I'm not sure what Create does the error refer to.
zerohalf@...
zerohalf@... wrote:
Error raised after this
In my opinion, this happens when trying to create a temporary file with the same name as in *nix containing special characters
What does it mean "after this"? What line throws the error? Please attach a full session log file showing the problem (using the latest version of WinSCP).
Re: log
You didn't answer my question and there's no error in the log.
I do not think the problem has anything to do with WinSCP.
If you believe it is, we need more information.
