Put Files Copying Folders
james0048
I'm trying to copy some files to a remote server without including the local directories at all using Powershell, for example I have the script setup like below.
$localpath1 = "C:\folder\approved\"
$localpath2 = "C:\folder\results\"
$remotepath = "\"
$filemask1 = "*.xslx"
$filemask2 = "*.pdf"
$session.put($localpath1, $remotepath, $false, $filemask1)
$session.put($localpath2, $remotepath, $false, $filemask2)
I want these files to be put just on the root of the remote server put it's creating the approved and results folder and putting the files inside of them. How do I make it so the folders aren't created?
Thanks!
James
