Host is not communicating for more than 15 seconds error with latest version of WinSCP on Windows 10
docmagda
MA, USA
Hi, WinSCP used to work normally for my connections and today it started showing this error. After I turned off the "Optimize connection buffer size." nothing really happened and the error persists. I do not know what to do but with COVID my job really relies on that. Can you please help me fix the issue? Thanks a lot!
UPDATE 3 JULY 2020: The issue got fixed without me taking further steps! I will update if it re-occurs.
Re: Host is not communicating for more than 15 seconds error with latest version of WinSCP on Windows 10
Please attach a full session log file showing the problem (using the latest version of WinSCP). Can you connect using any other client with the same protocol?
docmagda
Not sure what caused the bug but it got resolved automatically so now I am able to access my files
Thank you so much for the guidance! I will keep that in mind when I post any future issues to the forum to help you address them. When I re-tried now I am able to access my files normally though so I am unable to share the error. Not sure why it was happening but it got resolved now!!! I hope it will not re-occur. If I experience it again I will re-open the topic with the details you mentioned. I really appreciate the support!
