Command line scripting: Resume after connection loss skips files that are partly uploaded
RonWilliams
I struggle with bad internet connections and thus drops a few times during upload, but the WinSCP resumes after the connection loss but skip over the files that are partly uploaded.
option batch on
option reconnecttime 30
open ftp://*******:***********@154.8.160.197/
synchronize remote C:\WINDEXVIDEO\ /public_html/Repository/Video2020 -resumesupport=on -speed=100
Re: Command line scripting: Resume after connection loss skips files that are partly uploaded
